Oil pump alignment pics
  • Oil pump alignment pics
    For those that have asked, here are the two lines to align at idle, for older Sea-Doo oil pumps:
    wow. thanks!! i can't see the like on the pump housing on mine, but that picture helps a ton!
    Thanks!
    -bryan
    http://www.geocities.com/tbduke/
    Bryan Duke<BR>http://www.geocities.com/tbduke
      So Mikuni makes the Oil Pumps too !?
      I need a block off kit, does the SBT kit come with the gasket ?
      How do you deal with the Oil jets in the RV Cover ?
      David
      DAVID_HX_XP_RX-DI
        Yes, Mikuni makes all the pumps. Yes we sell kits for $15. You don't need gaskets with the kits - for those few pumps that use an o-ring, you transfer the o-ring to the plate. For those that are flat you just use a small bead of your favorite sealant. The kits include rubber caps for the injection fittings.
          Any marks on the XP 800 motor oil pump(on front of flywheel cover)??
            Yes, they all have marks.
              do i have to re-align, if I didn't make any adjustments to the linkage from before engine installation?
                No.
                  i have a 96 gsx ..can you show me a picture of how the lines on the oil pump should lined up and how to do it or sea do it ...ha ha ..thank-you
                    With the throttle cable properly adjusted, and the idle speed properly set, adjust the oil cable so the two lines shown above line up with the throttle at idle.
                      my oil pump does not look like the one in the picture...and i was told to check at wot...i also don't see any lines even when looking up close...thank you again
                        I think whomever told you to check it at WOT was confused. You check the FLOW at WOT, but you set the alingment at idle.
                        There are lines there - if you can't see them it's just too dirty or you just aren't looking hard enough. I'll post pics of an 800 for you tommarow.
                          thanks again ...i promise i looked as hard as i could! i even pulled it of and looked reeeeeeaaaaal close..mabeye my marks wore off..thank you again for the up coming pics! [img]smile.gif[/img]
                            ok so this picture here. when the oil pump is mounted on, where are these twol lines. on one of the side, underneath or on top? and can i see them while the carbs are still atatched or do i gotta take it all apert to see em? I noticed when i take out the plugs on my doo, they are covered in more oil than anything else, so i was jsut wondering if it is beacsue these two lines aren't lined up or if it is normal? They are covered with what seems a mixtures of gas and oil, but really balck like there is toooo much oil in em. but i dunno. Thanks
                            • #15
                              When mounted, it will look just like you see it! You will probably need a mirror and flashlight.
