- Flush the ski
http://server1.sbtontheweb.com/forum...ad.php?t=12000
- Change the oil
http://server1.sbtontheweb.com/forum...ad.php?t=13979
- Remove the two fuel rail bolts, the rail and fuel injectors.
- Spray Bombardier Lube for 3 seconds into each injector port.
- Hold the throttle wide open and crank the engine over for 5 seconds.
- Inspect the injector o-rings and replace if needed. Lube them with oil before reinserting them.
- Use Blue Loctite on the rail bolts and torque to 7 ft/lbs.
- Remove the engine cover and disconnect the ignition coil connectors.
- Remove the coils, cleaning off any dirt.
- Remove the spark plugs and spray Bombardier Lube down each spark plug hole for 3 seconds.
- Reinstall the spark plugs and coils.
- Apply Molykote 111 to the coil connector edges and reconnect them.
- Reinstall the engine cover, it'll snap closed.
- Remove and store the battery.
- Change the oil
