I am doing a top-end job on this ski. SBT parts are on the way. I am blocking the the oil and going with pre-mix. (The oil hose came lose on the rear carb burning the piston and cylinder.) What gas/oil ratio should I use? I was planning to use 40:1 but have read different things.
99 XL1200LTD gas/oil ratio
Re: 99 XL1200LTD gas/oil ratio
I just started to pre-mix oil in my 2001 xlt 1200 with a new SBT engine and have read two mixes the first, 32:1 which I started to use in the first 2 tanks (where I am at now) and it smokes a lot at idle but not so bad when cruising but the plugs are black and sootie? looking. I plan to start mixing at 40:1 and see if it helps. I removed the converter, installed a "D" plate, but am still using the last of the YamaLube I have.
Iam also a home builder, which explains why I have so much time to play with the toys. Things could be worse, at least we are working some, not a lot but enough to stay in the business. Good luck with the ski.
