My ski has two hoses the come through the rear bulkhead into the engine compartment. One, the 1/2" hose is disconnected and plugged. The other hose, 3/8" dia, goes into a T and splits off to a couple of places on the aftermarket Coffman exhaust.
The flush line is tapped into a line running into the back of the block/head. When flusing, the water-jacketed Coffman exhaust is cool, the engine/heads are cool, and water comes out of the side vent toward the front of the ski and out of the exhaust.
In the water, the exhaust is very warm, as is the block and head. No water that I can see is coming out of the side vent.
How much water should be being fed to the engine/exhaust when the ski is in the water? Is the 3/8" hose enough, or should that capped off 1/2" hose be used?
