I recently purchased a used 2000 superjet, which on the second ride had trouble with the motor stalling out when accelerating from low-mid range rpm's. To get it started again, I would pump the primer (previous owner installed) and get back to plane, then it would die down again. This ski was stored (indoors) for over a year, the carbs had been adjusted for higher elevation riding for which I have set the adjustment back to the supposedly "marked" stock setting. Any suggestion on where to start? hard to tell if the primer system is installed correctly, nothing to compare it with. Seems to be starving for fuel?
Suggestion appreciated!!
Chris
Chris
