I bought a 1997 sea doo xp. I want to do a rebuild (my first and i'm still in school to learning how to do it at MMI) and I want to get the right parts and everything I need to do the job through you. Sounds like a lot of business for you guys but I like your product, I want to start practicing on my own so please help me right and I will give you plenty of future business. What lubes, oils, gasket sealers, and other things can I get through you or do I need to get the job done right. The motor is a 787 CC, I am also interested in new j-1171 fuel lines. I will probably come down next week or maybe this weekend to pick everything up if you have it all in stock. I am also going to have someone bore out my cylinders, I don't know if I will do that in Orlando or leave that to you as well. Assuming the rods and crankshaft are fine, i just would need piston parts and new bearings. I believe I have to get new head bolts as well right?
This is basically an order and you weren't open when I called so I figured I'd write on here since I can get advice from others as well.
