I've got a 1990 Sea Doo SP with a yellow 580 motor. The ring gear went bad so I bought another flywheel off ebay. The ski wouldn't crank. After exchanging emails with the seller, turns out the flywheel is from a 1992 SP with a white motor. From what I can by searching the forums, a white motor flywheel won't work on a yellow motor.
So, I find I local salvage yard, drive 2 hours (Atlanta traffic sucks) and arrive home with what they tell me is a flywheel for a yellow motor. Ski still won't crank. After comparing the numbers on the flywheels I suspect the salvage yard lied to me.
I need help identifying what flywheels I have now so I can make sure the next one will be correct. Here are the numbers.
original flywheel that the ski ran with - 032000 - 7001 11JX
eBay flywheel - 032000 - 7091 2MY
salvage yard flywheel 032000 - 7091 9MX
