After de-winterizing, took my first ride yesterday. I'm still losing coolant, even after re-inspecting all hoses, clamps, etc and pressure checking system. Did notice a very small amount of coolant coming out of weep hole at base of water pump. Had to use small inspection mirror even to notice that. Anyone experienced a rotary valve failure? Or is this normal? Should I be looking for any other problem areas?
2002 GTX 4TEC still leaking coolant!! HELP!!
This topic is closed.
Re: 2002 GTX 4TEC still leaking coolant!! HELP!!
