water valve removal
  • water valve removal
    Does anyone know how to remove the Rave water valve on a gsx limited to dry out the waterbox?? Is this even possible?
    Re: water valve removal
    Anyone ??????
      unscrew it .. very easy
        I guess I should explain more, when I say dry out, I meen remove the valve and re-route the water. The valve will leak over time and I heard that ot can be removed and actually get better performance!!
          It can be removed by unscrewing it obviously, your question seems to be what is typically done. I would hope it is still available, Rossier when that ski first came out offered a jet kit for the water box, just a few brass fitting to jet a small amount of water into the box to keep it from melting the foam etc. Try giving them a buzz.
            Thanks
              Rossier stopped making that kit, they said they might be able to put one together, but I can probably do the same thing!
                I found this on another site, posted by W.Wx. on how to remove the water regulator
                The big line coming to the water reg is the feed line,connect it to a 1/4 tee if the feed line is bigger put a 1/4 hose on the tee and cut off flush with barb,this makes the barb a little bigger so you can plug the bigger feed line on it. (Hope I havent lost you yet)
                Take the brass fitting out of the water box & replace with the same size 1/4 barb fitting that is on your exhaust pipe,run a piece of hose to the straight part of the tee to the new barb fitting on the waterbox,make sure you are sending the water into the water box thru the staraight part.
                The T side hook up your hose that feeds water to the exhaust pipe,right about where yours started turning brown.
                You can tap the ends of both brass barb fittings (water box & pipe) with a 5mmx.080 metric tap this will allow you to adjust water flow thru these lineswith a carb main jet,the water box can pretty much take all the water the fitting will allow with no adverse affects.
                Im kinda lost after trying to follow it, can anyone draw this out??
                  Jet Works sells the kits. 949 548 5259 Ask for Art.
                  Bill O'Neal <br>
