I have a 92 seadoo spi and am changing the pump oil for the first time since I bought it. I took the impeller venturi off, and am took the three screws that attach the impeller housing cover. All 3 are out but the little cone will not come off? do I need to take anythign else out? the filler plug? Also what oil shoulf I use for the impeller housing? and any tips on reinstallation? sorry for the rookie ?'s I am a beginner at skis but take pride in doing my own work.
Quick help on jet pump oil change!!!
85 Kawasaki JS550
http://www.cardomain.com/id/thegraytta
"Keep your nose out of the sky
Keep your heart to God
Keep your face to the Rising Sun"
Tags: None
Re: Quick help on jet pump oil change!!!
got it off thanks, the oil looked nice and black not milky. What do I need to go buy from the seadoo dealer? The o ring on the impeller cap looks good. also the 2 little o rings on the venturi looked pretty good. do i need any gaskets or locktite?
85 Kawasaki JS550
If you would do what I posted you would already have your answers! http://server1.sbtontheweb.com/forum...ead.php?t=4088SBT Tech Support is here to help with your problems.
